I'm working on a project that requires an array of RGB LEDs and the total current consumption has to change depending on what is powering it. I'm using the TLC59711 and designed a way to change the constant current setting by adding a single MOSFET and resistor. I'm pretty happy with how it works, and hopefully it'll be of use to someone else!
