I'm adapting a circuit that fires a model rocket engine after a time delay. It is basically two 555's in monostable configuration, the first trigger the 2nd after a time period, the second then fires the igniter through, in the original plans, a darlington power transistor. I have built one launcher this way, but would like to use a power MOSFET for my MkII...
This is the basic schematic I have. This has been tested, and seems to function....
(I've obviously not included the timing/trigger parts of the 555)
Is this the correct way to wire a MOSFET - does the MOSFET, or the 555 need a resistor on the MOSFET gate?
Is 10k OK for a pull-down resistor?
Cheers
Lee
