I'm currently looking at ways to get power into a rotating (30rpm) chandelier for a 1-off project. We're concerned about long-term wear issues with slip-rings ( as well as the high cost of good quality ones).
I'm thinking about using a rotary transformer, but don't know much about magnetics.
Requirements :
Max size about 65mm dia x 50mm high
Power about 100W, continuous duty.
Output voltage ideally 48ish, and load regulation of about 25% would be OK
Input voltage : completely flexible.
Don't care about efficiency as long as nothing melts!
One possibility is Medum power Qi, which can supposedly do up to 65W, but this looks like being at the low end of what we need, and there doesn't seem to be much hardware out there above 30W at the moment.
Suitable magnetics seem a bit thin on the ground.
Something like this would be perfect, but struggling to find anything off-the-shelf at a sensible price
The next best thing would seem to be a standard circular pot-core like this
Obviously the gaps at the sides would have some effect, but how much ?
What sort of core material should I be looking at?
I'm thinking frequency in the 50kHz range ?
The gap would be as close as we can get within mechanical tolerances - guessing 1-2mm
It would be nice to avoid the need for any feedback for regulation ( i.e. output determined by transformer ratio) - is this realistic for, say, 25% regulation?
This paper has some useful info, though I don't understand teh function of L1/CR1 in fig. 1909
https://coefs.uncc.edu/mnoras/files/2013/03/Transformer-and-Inductor-Design-Handbook_Chapter_19.pdf [ Specified attachment is not available ]
Any thoughts welcome.
