Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
RPi Compute Module - mechanical support?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: RPi Compute Module - mechanical support? (Read 822 times)
David Chamberlain
Regular Contributor
on:
June 10, 2019, 06:14:05 am »
So I have a Raspberry Pi compute module design. When I did the PCB I put the same 2.3mm holes below where the holes in the CM SODIMM are with the idea of sticking some sort of standoff / spacer in later to provide additional mechanical support in adition to the spring loaded clips of the 200pin DDR2 socket.
Well later has come and I just cannot find anything suitable, for the next run I could enlarge the hole in my PCB but was hoping someone might be able to link me a product that works. I would rather not resort to a plastic spacer, washers, nut & bolt combo if I can help it and was hoping for something more elegant.
These are good but the recommended drill size is 3mm.
https://www.digikey.co.nz/product-detail/en/wurth-electronics-inc/702912000/732-9621-ND/5843781
Or these solder metal screw mounts, would also be good but again it's a 3.5mm mount hole, but worst the screw is a M2.5 so larger then the holes in the CM.
https://www.digikey.com/product-detail/en/wurth-electronics-inc/9774025151R/732-7078-1-ND/5320683
BTW I hate these double ended snap lock ones with a vengeance, please do not recommend them.
https://www.digikey.co.nz/product-detail/en/wurth-electronics-inc/709650500/732-10354-ND/6174573
Or just tell me I should have put a bigger hole in my PCB
Thanks
Davod
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
