Author Topic: rPi direct to MIPI DSI LCD panel?  (Read 2001 times)
Offline MWPTopic starter
« on: February 12, 2019, 06:36:46 pm »
Hi all,
I have a project in mind where space is a premium, so im looking to use a rPi compute module, and making my own "motherboard" with a slim LCD panel.
I dont have room to deal with HDMI cables / converter boards.
So does anyone know of examples of an rPi directly driving a MIPI DSI LCD display panel?
I havent found much so far.
Thanks in advance!
Offline james_s
Re: rPi direct to MIPI DSI LCD panel?
« Reply #1 on: February 12, 2019, 06:49:45 pm »
I saw a page somewhere about that but now I don't recall where it was. As I recall, the problem is that most modern DSI displays have more lanes than the interface on the RPi provides but I'm pretty sure there was at least one that worked with it.
Offline ajb
« Reply #2 on: February 12, 2019, 07:50:00 pm »
Aren't native DSI displays also fairly hard to find in small quantities?  Last time I looked that seemed to be the case, lots of Alibaba sellers wanting 1000 piece orders but not much else.
Offline SiliconWizard
« Reply #3 on: February 12, 2019, 08:24:25 pm »
Offline james_s
« Reply #4 on: February 12, 2019, 11:31:41 pm »
There are a lot of small DSI displays available from Chinese sellers, especially OLEDs and replacement smartphone screens. Most of them are newer generations though, the RPi DSI interface is sort of 2010 era smartphone tech.
« Reply #5 on: February 13, 2019, 04:12:47 am »
Thanks y'all.
I have just come across this which looks promising...
https://www.thearkadia.com/
0 details yet though.
Offline tsman
« Reply #6 on: February 13, 2019, 04:27:53 am »
Thanks y'all.
Unlikely it is DSI. This looks to be a parallel interface and will use the DPI peripheral in the Raspberry Pi.
Offline technix
  • Country: cn
  • From Shanghai With Love
    • My Untitled Blog
« Reply #7 on: February 13, 2019, 07:35:52 am »
If you are using compute module, it might be better for compatibility to run HDMI traces on your board, and use converter IC to get whatever protocol you need.
