a bit afraid i will end up messing-up my enclosure
Me too, but I’ve done a couple of them so here’s my advice.
Most of all, take your time. Take
plenty of time measuring and test-fitting.
For the connector, you can use either a panel-mount connector wired to the PCB, or a PCB-mount connector that sticks over the edge of the board and pokes out of the box.
Measuring: Get the dimensions or mechanical drawings for the enclosure and the connectors, switches, etc. If you only need one hole for a panel-mount connector, the location of the hole may not be critical and you can just eyeball it. However the size & shape of the hole always matters. If you don’t have proper dimensions for the parts then measure or trace them.
If you need things to line up properly then you have to measure everything from one fixed point. This is where you want a drawing of the enclosure that gives the locations of the PCB mounting holes.
Make a sketch that shows the measurements required to put the holes in the right places.
Cutting: The tools I use most are:
- drill
- nibbler
- files
- X-acto knife (for labels, templates etc.)
Dremel tools are popular, I’ve just never used one.
If the edge of a hole is going to be visible, you might want to cut it a bit small and carefully file it to size.
Robustness: A panel-mount connector will be strong if it’s installed properly. For a PCB-mount connector, use one that has a couple of mounting tabs, not just 4 tiny pins.
