Author Topic: HADBEST HB070 reuse  (Read 1311 times)
Offline baitorTopic starter
  • Country: at
HADBEST HB070 reuse
« on: January 11, 2018, 06:23:20 pm »
Pretty sure I pulled this thing out of an old touch screen printer. One of those wankey IOT ones from ten years ago.
Full marking in the top right corner of the back reads: HB070-AB182-06H
I'm trying to reuse the thing as a small PDF reader.
It's got a 4 pin flat flex for the touch screen and a 25 or 26 pin flat flex for driving.
Where the hell am I to find the pin out for this thing??
Is there a common pin out shared between older LCD panels like this or some driver someone can recommend that will work for it? I tried looking it up on beyondinfinite DOT com/library DOT html but there are too many entries to go through and none are marked with the same part number.
