Author Topic: RS485 Input Voltage Levels  (Read 225 times)
Offline Sparky84Topic starter
« on: December 13, 2024, 11:18:00 am »
Hello,
I am a little rusty on RS485, and I am unsure if it will read a (0-5V) PPS input signal.  I have a spare RS485 input and I thought this would be a simple way to read a (0-5V) PPS signal into a 3V3 microcontroller.  So essentially the signal path would be as below:
PPS (0-5V) -> RS485 -> UART -> Microcontroller
I think this should work, but I just needed a second opinion before I get the soldering iron out  :D
Many thanks,
Sparky84
Offline David Hess
  • DavidH
Re: RS485 Input Voltage Levels
« Reply #1 on: December 13, 2024, 12:12:59 pm »
A RS-485 input should read a 0 to 5 volt digital signal just fine.  A DC input at the other RS-485 input sets the threshold and the RS-485 receiver then operates as a comparator.
Offline Doctorandus_P
« Reply #2 on: December 13, 2024, 01:32:16 pm »
RS485 is a differential signal, and you always have to use the two wires to get the voltage difference. But you can indeed use a DC bias voltage on one of the wires and then use the RS485 transceiver as a comparator.
