Author Topic: RTB 2004 Battery Mod  (Read 1354 times)
Offline sixtimessevenTopic starter
    • Flickr
« on: July 20, 2019, 09:08:43 pm »
I was wondering if there is a project / mod adding a battery to the RTB 2004 oscilloscope?
There is a lot of space in there and it would be very usefull to me. It would be pretty straight forward to do since the 2004 is supplied with a single 12V rail from the ACDC module... Perfect for a 3-cell Lipo replacement I think.
However, why reinvent the wheel...
Offline InductorbackEMF
  • Repair/Rebuilding.
Re: RTB 2004 Battery Mod
« Reply #1 on: July 20, 2019, 10:03:10 pm »
Hi,I was thinking the same thing for the RTM3004 same single 12v rail.
May be worth testing the power draw to get a feel of how long it would run with some Lipo cells.
If you do go ahead please say so!
Alex.
Want a cup of TEA? (just one more meter please..)
Alex.
Offline NiHaoMike
    • Facebook Page
« Reply #2 on: July 21, 2019, 03:22:09 am »
If it does require just 12V, a 3S pack with a BMS will indeed work nicely. Certainly easier than on other scopes such as my GDS-1062A that need several DC/DC converters.
Someone modded a Rigol to run on batteries.
https://www.eevblog.com/forum/chat/()-rigol-ds1052ed-power-supply-dc-voltage-add-battery-pack/
    • Flickr
« Reply #3 on: July 22, 2019, 08:25:07 pm »
I measured the current drawn after boot up to be 3 A idle and 3.4 with all four channels enabled. Voltage is pretty spot on 12V. I measured 11.97V with my DM3068 meter.
Indeed, just a single 12V rail. Nicly broken out from the shield and with a 4-Pin Molex which looks like a smaller version of the 4-pin ATX connector. Probably this one: https://www.molex.com/molex/products/datasheet.jsp?part=active/1053081204_CRIMP_HOUSINGS.xml.
Thanks Rohde Schwarz  :-+
Edit: Just found the power supply:
https://www.digikey.ch/product-detail/en/xp-power/ECS65US12/1470-1296-ND/4487677
Credit to Mike!
« Last Edit: July 22, 2019, 09:03:21 pm by sixtimesseven »
Online coromonadalix
« Reply #4 on: July 22, 2019, 10:30:09 pm »
Tons of emptyness to play with ??
    • Flickr
« Reply #5 on: July 23, 2019, 09:34:33 am »
Would be plenty for my 4s 8000mA RC battery I have laying arount. To bad it is not 3s.
