Author Topic: SMD Cheat Sheet  (Read 14349 times)
Offline pighixxxTopic starter
SMD Cheat Sheet
« on: April 07, 2015, 02:28:48 pm »
Hello to everyone,
I just finished a SMD cheat sheet; Any suggestion or criticism is welcome  ;D
Download the PDF here: http://www.pighixxx.com/smd_v1_0.pdf
Offline KD0CAC John
Re: SMD Cheat Sheet
« Reply #1 on: April 07, 2015, 02:48:20 pm »
I can use the info , but not knowledgeable enough to give helpful criticism .
So waiting for peer-review before download ;)
Thanks
John
Offline KD0CAC John
Re: SMD Cheat Sheet
« Reply #2 on: April 07, 2015, 02:51:51 pm »
Another chance to do this , on posts that are of interest , I will click on notify .
Then my email will flood with irrelevant threads , and in some cases no notify of the original thread of interest ?
I have posted this at least half a dozen times with no replies , or at least no notify's , hoping to one day solve this ?
Offline voja
Re: SMD Cheat Sheet
« Reply #3 on: April 07, 2015, 04:06:14 pm »
Great job, pighixxx!  :-+
It could be very handy, but I wonder how to apply the correct scale if I print the sheet on the paper. When I tried to print it as PDF, I've got the wrong scale, e.g. 2.3 mm instead of 2,54. It is even worse on the screen, as it will be represented at some unknown scale.
Wouldn't it be more convenient if there were printed dimensions (in inches and mm) above every package - at least for pitch and overall width?
Offline owiecc
    • Google scholar profile
Re: SMD Cheat Sheet
« Reply #4 on: April 07, 2015, 04:51:09 pm »
– Watts are "W" not "w"
– Use "times" sign (×) instead of ex "x".
– In SMD grids are important. So, as far as I can remember, 0.5mm pitch IC "matches" one of the sizes of passives. I don't remember which one.
– You could add via current rating.
– CAPS Value Converter is unnecessary IMO. Only old people don't know what a nF is :)
– I would add common pitch values (0.35mm, 0.4mm, 0.5mm) to Units Converter.
– You can add how many traces and which width can go between SMD passive of various sizes.
– Add samples of BGA fanout methods
– Maybe a cross-section of a good SMD solder job (SMD passive and IC leg).
– Samples of SMD pad sizes vs. component density
And as a bonus for various expos/conference visitors:
– How many SMD components of a certain size fit into a jar
« Last Edit: April 07, 2015, 04:54:29 pm by owiecc »
Offline bitwelder
Re: SMD Cheat Sheet
« Reply #5 on: April 07, 2015, 05:00:34 pm »
I think it would be a good addition to e.g. surround a large block in the middle with a square of specified dimensions (around 100 x 100 mm) to to verify if the printout has maintained the intended sizes.
Also, I guess the the pdf has been generated for an European A4 paper.
Not sure if the sizes are maintained when printed on US Letter format (A4: 297 × 210 mm, Letter : 279.4 x 215.9 mm)
Offline free_electron
    • SiliconValleyGarage
Re: SMD Cheat Sheet
« Reply #6 on: April 07, 2015, 07:14:01 pm »
sc70 package missing
sot 523 missing
wide electrode parts missing like 0612 and 1218
dont't draw em as a blob. show the electrodes. same for electrolytics. large electrolytics have support pads missing
current rating missing on traces. also show outer and inner
tssop packae wrong
ssop package wrong
there is also a 200 mil wide so package (TI and toshiba)
show more tqfp and qfn
plcc ?
more awg diameters
units converter
from metric to imperial.
0.5mm
0.8mm
1mm
1.5mm
2mm
2.5mm
pitch references for flatpacks :
1mm
0.8mm
0.75mm
0.65mm
0.55mm
0.5mm
0.4mm
Re: SMD Cheat Sheet
« Reply #7 on: April 07, 2015, 07:26:17 pm »
Thanks to all!
I'm collecting all the information to improve the sheet.
It 's just a sheet so you have to choose what to put ;)
I will also the Letter version.
a gift: http://pighixxx.com/ne555pdf.pdf
Offline Fred27
    • Fred's blog
Re: SMD Cheat Sheet
« Reply #8 on: April 07, 2015, 08:50:29 pm »
How exactly are you supposed to use it?
Offline zapta
Re: SMD Cheat Sheet
« Reply #9 on: April 07, 2015, 09:20:31 pm »
Too small on my screen. Can you post a PDF?
Looks very useful. Especailly the package outlines. Would useful to have also text at different sizes (e.g. for silkscreen).
Re: SMD Cheat Sheet
« Reply #10 on: April 07, 2015, 09:29:11 pm »
On the first post you can find the pdf.
For your convenience: http://www.pighixxx.com/smd_v1_0.pdf
In the coming days, I release an improved version.
@Fred27
Usually, I release my drawings when I can not find anything that suits my case.
Mainly as a conversion tool (electrolytic capacitors with different codes) and then I expanded the tool...
Offline PeterFW
    • Stuff that goes boom
Re: SMD Cheat Sheet
« Reply #11 on: April 07, 2015, 09:34:05 pm »
Looking forward to that, this looks very handy if the few missing parts and descriptors are fixed :)
The TQFP/QFP/QFN are a bit redundant to me,
i would either add alle of the usual packages or leave them out.
Offline harrimansat
Re: SMD Cheat Sheet
« Reply #12 on: April 09, 2015, 05:53:20 pm »
Thanks for post!
Offline JoeN
  • We Buy Trannies By The Truckload
Re: SMD Cheat Sheet
« Reply #13 on: April 09, 2015, 08:43:09 pm »
I think the idea is print it out.  Assuming the dimensions are true, you can just eyeball your component against what's on the paper to determine what it is.  Also, knowing your component type, you can eyeball the part on the page to tell how much space it is going to roughly take up on a board.  Also, if you are a noob it's a quick way to learn a bunch of common package types.
Next step will have to be flashcards!  All really gung-ho types love flashcards.
http://www.smallarmssurvey.org/fileadmin/docs/M-files/SmallArmsSurvey_ID_PlayingCards.pdf
http://itunes.apple.com/us/app/tank-flip-flashcards-tanks/id356298807?mt=8
Have You Been Triggered Today?
Re: SMD Cheat Sheet
« Reply #14 on: April 28, 2015, 10:01:10 am »
New version!
Hi to all,
I removed some information and added more.
Now you can download the letter version.
it's still a beta version
Suggestions are welcome!
The following users thanked this post: Gelf54, mixiom, Mr. Scram, pikey
