Hello Guys!
After sorting out the transformer configuration problem for my dual voltage supply, another problem exists now. The digital voltmeter i am using has three wires:
1) +12Volt (to turn on the voltmeter)
2) Ground
3) Voltage Measuring
The voltage is measured with respect to ground wire.
However if i connect the voltmeter supply terminal to +12 V and ground and then measure - voltage it does not measure the voltage. The output voltage shown is zero. I was thinking to use op amp 741 inverting configuration with gain of -1 to convert the -ve voltage to +ve voltage but the op amp VCC and VEE limit is 20 volt and my output voltage is 20+.
Any suggestions to resolve this issue?
