Author Topic: Looking for beta testers for a new product  (Read 515 times)
Offline erikkaTopic starter
« on: February 22, 2025, 11:30:13 am »
For a new product I'm looking for a number of testers, preferably in Europe
The product will be a new member of the tiny devices family and has high resolution dual time stamping and frequency/phase/counting measurement capability
Frequency/time/phase reference can be external or internal using a built in gpsdo.
The accuracy is less then the tinyPFA but it has much more functionality.
No specific test equipment availability is required but it's important to have a project that can benefit from the above functionality to ensure actual usage.
If you are motivated to join the testing and do have sufficient time to frequently load, test and report on firmware updates, please send me a private message with some info on your project(s) and how you intend to use the product.
If available, you can add some info on your experience and relevant test equipment
Replies to the list will be ignored.
