Preface:
This is NOT my design! I'm simply trying to troubleshoot it.
Background:
I have a tool that employs two LVDTs to measure differential thickness of sheet-type materials. The LVDTs have self-contained internal circuitry for excitation/oscillation and to output a DC voltage that is proportional to its displacement. I have no clue about the internals.
Each LVDT has four wires: 6V (nominal) supply, ground, output_high and output_low (the latter two make up the differential output). Each LVDT's output (i.e. difference between output_high and output_low) is highly depending on its load (i.e. open circuit = higher voltage, load resistor = lower voltage). Also, I've found that the LVDT outputs are dependent on the supply voltage (i.e. higher supply = higher voltage between output_high and output_low).
There are two LVDTs in the tool. The output_low wires from both LVDTs are tied. The output_high are attached to either end of a 1.3k ohm resistor and the signal is essentially the voltage across the resistor. I do not know the nature of each LVDT's input impedance (it is not constant and not a simple resistance).
Problem:
Though both LVDTs are sufficiently linear, one of them scales differently than the other. In other words, if I were to displace both LVDTs the same exact distance, the output voltages will be off by a bit. Think: output x some constant. Another way to think of this is that when the individual LVDT outputs are plotted, the line is straight but the slope is off.
Proposed Solution:
I know that the each individual LVDT's differential output is dependent on its source voltage. I would like to trim the supply voltage on one LVDT. I'd like to avoid messing with the 1.3k load or anything else on that end, as the LVDT outputs are unpredictably dependent on its output load. I need a very simple and elegant way to shed 0.05-0.3V on one LVDT's supply. I was thinking about using a spliced-in, low-voltage-drop diode, but too bad it's not adjustable and the voltage drop might still be too high. The other option is to construct a small circuit, but I'd really like to keep it as bulletproof and idiot-proof as possible. Can you guys think of any other options?
THANKS!
Ken
