NiCd , even though packs have an internal fuse , it does not mean most cells doesn't have , i actually cut a busted NiCd open to find a HRC fuse inside on the positive side .
So, you posted that link to show that NiCd's have internal fuses... Yet the link never talks about internally fused cells. And your explanation is that "...it does not mean most cell doesn't have..."
In my over 25 years of experience designing battery packs, and battery pack electronics, I have never seen a Ni pack with an internal fuse. Most cells do not have fuses. I was willing to believe some could, so I asked for some evidence, so you send me on a boondoggle, to an article that doesn't back up anything that was in question.
I'm sure you believe you saw a cell with one, have zero knowledge other than what you believe you saw, and were probably mistaken in your analysis. It is possible to make a cell with an internal fuse, but doing this would have very little benefit to the cell manufacturer, as they would then have to stock different cells with different fuse ratings. I just can't see a good reason to do it, can see lots of downside, and you offer no real evidence other than "I saw it".
Can you understand why your argument isn't very convincing?
By the way, I have quick access to cell data sheets from every major cell manufacturer. If you give me a cell manufacturer, and model number, I can look this up quickly. If most cells have this, as you say, then giving me a major manufacturer's model number for one, should not be difficult.
