Plug a BNC-BNC cable into it and now you have a male pin on the end that's live.
Or plug in a BNC-croc clips lead.
or plug the output into something else by mistake with a BNC-BNC lead.
Unmate a standard BNC cable from it when it's live and if the shield breaks before the centre pin, the part you are holding becomes live via the load on the end.
These are all things which make me not want to use BNCs. Especially when you have to write the things above on a risk assessment
