Author Topic: Description of Pulse Train FM Detector on Github  (Read 459 times)
Offline kvdTopic starter
« on: April 13, 2021, 11:28:18 am »
On Github I published a project with a detailed description of the workings of a Pulse Train FM Detector. This is accompanied by a mathematical model, implemented in a Jupyter notebook with which experiments can be done. In the pdf document also a possible improvement is mentioned, together with some preliminary experimental results.
The project can be found at https://github.com/kvdijken/Pulse-Train-FM-Detector.
The main document (pdf)  of this project is attached to this message.
This FM detector is also used in an actual FM receiver designed and built by myself. There is a github project for the receiver, at https://github.com/kvdijken/FM-Receiver. I have a demonstration video of this FM receiver on youtube: https://www.youtube.com/watch?v=TlIiLwKdwg0&t=1s.
Greetings and have fun, Koen
Offline pardo-bsso
  • Country: ar
Re: Description of Pulse Train FM Detector on Github
« Reply #1 on: April 13, 2021, 11:52:54 am »
Hi Koen, nice writeup.
Your urls have a dot appended at the end and thus are not working properly.
(also, I see that you cross-posted this into the RF forum too)
