Author Topic: ltspice simulation problems  (Read 2669 times)
Offline jmelsonTopic starter
« on: May 23, 2019, 09:45:30 pm »
Couldn't find a good place to ask this, if there's a more proper place, let me know.
I was trying to simulate some one-shots, tried to add the 74HC4538 to my favorite sim (Protel 99SE) but couldn't get that to work.
So, I added the 74HC and everything else model library from texane for LTspice.  I threw together a test circuit, but I can't get ANY comparators to work properly.  I tried a bunch of LT's own parts, they gave a low DC output.  The only one that responds at all is the LM319, but it is VERY weak, only gives nanoamps of output, and it appears to be phase reversed.
Here's the schematic file from LTspice:
I hope it is obvious what I'm doing wrong, i'm a real neophyte with LTspice.
Thanks,
Jon
Offline T3sl4co1l
    • Seven Transistor Labs
Re: ltspice simulation problems
« Reply #1 on: May 23, 2019, 11:25:58 pm »
You put the libraries where??  What is "ZZZ\\LOGIC\\74HC\\"?
Seven Transistor Labs, LLC
« Reply #2 on: May 24, 2019, 01:49:28 am »
That's where the huge file from
https://yadi.sk/d/6nSSUmZiT9oCoQ
had all the 74HC stuff I wanted, so I just kept it the same.  It does work.
It looks like my comparator problems were just that I was making the input pulses too short.  Once I slowed down the pulses, it worked, at least using the LM393 comparator.  GOOD THING I pressed on and simulated this circuit, as it does NOT work as designed.  But, now that I have the simulator actually working, I can try to fix the logic.
Thanks,
Jon
« Last Edit: May 24, 2019, 01:52:28 am by jmelson »
Online iMo
  • Country: bj
« Reply #3 on: May 24, 2019, 03:08:01 am »
ZZZ is the Bordodynov library - he created and updates from time to time a large bundle with a lot of components and examples.
« Last Edit: May 24, 2019, 03:49:42 am by imo »
« Reply #4 on: May 24, 2019, 05:00:09 pm »
And, it is GREAT!  It adds all sorts of jellybean parts to the proprietary LT parts.
Jon
Offline lordvader88
« Reply #5 on: May 26, 2019, 04:20:02 pm »
excellent, I too shall use these files, if i can find install instructions, otherwise it will sit on my drive
Offline hugo
« Reply #6 on: May 26, 2019, 05:41:48 pm »
It's easy to use these files:
- use this folder for symbols
C:\Users\Joe\Documents\LTspiceXVII\lib\sym\ZZZ
- use this folder for libs and subckts
C:\Users\Joe\Documents\LTspiceXVII\lib\sub
This is Bordodynov's home page :
http://www.bordodynov.ltwiki.org
The following users thanked this post: 3roomlab, Wolfgang
Offline steve1515
« Reply #7 on: August 04, 2024, 11:16:19 pm »
I just installed LTSpice 24 and copied the files from Bordodynov's zip file into C:\Users\Steve\Documents\LTspice\lib, but they don't show up when adding a component. Do I have to change any setting in LTSpice's search path?
I just have the defaults of...
User libraries directory: C:\Users\Steve\Documents\LTspice
Symbol Search Path = <Blank>
Library Search Path = <Blank>
