Author Topic: S/PDIF Chip  (Read 5248 times)
Offline rolheiserTopic starter
S/PDIF Chip
« on: April 21, 2015, 05:29:05 pm »
I am looking for some direction in choosing an S/PDIF to I2S chip. I need a chip that is quite basic, only looking for something that has non-PCM detect functionality and reset/power down. I have seen some from AKM and Wolfson and was wondering if anyone has some experience in using these chips and can suggest one that works well.
Thank you
Offline dom0
Re: S/PDIF Chip
« Reply #1 on: April 21, 2015, 05:57:46 pm »
dir9001
Offline bktemp
Re: S/PDIF Chip
« Reply #2 on: April 21, 2015, 06:33:16 pm »
CS841x
They can be used stand alone or connected to a microcontroller.
Offline linux-works
    • netstuff
Re: S/PDIF Chip
« Reply #3 on: April 22, 2015, 03:15:29 am »
I've done a lot of spdif and audio stuff.
wolfson 8804 and 8805 are nice receiver/transmitter chips.  a bit strange in software mode but easy to use in hw based mode.  uses a FIFO inside to lower jitter (or, raise it, if you happen to be below the chip's jitter level).
the 8416 is high jitter on input, but it has some nice points (select of 4 inputs even in hw mode).
AK has very nice chips (I have yet to use them but I have samples waiting to be explored).
my current project, in fact, is an spdif switch using the wm8804 (for repeating/shaping) and something else as a front end to it, for input selection (the 'switch' part).  output is spdif but there's also i2s if you need that.
you can buy a demo 2in 2out wm8804 board from ebay for about $20 and you can try it out easily and cheaply.
here's mine decoding an 88.2 sacd audio file:
I'm sending wordclock into the freq counter (part of my project is to send WC into the arduino and have it display the samplerate on the selected input.  in fact, that part is done and working:
button selects input, led display shows the input 'name' and the number on the far right is the freq-counted samplerate, all done on the arduino nano (on breadboard).  even has IR remote for display dimming/blanking and input select.
no software to the chip, though; its in pure hw mode and is simply just giving me wordclock, plus I'm doing input selection via a temporary hack.  its just an early proto, afterall ;)
I like the wolfson chips, overall.  this one can receive, transmit and give i2s out all at the same time.  the output spdif is FIFO'd and so has lower jitter (likely) than the input signal.
Offline SteveyG
  • Soldering Equipment Guru
Re: S/PDIF Chip
« Reply #4 on: April 22, 2015, 12:16:45 pm »
Seconded on the Wolfson chips, I used them in my (ongoing) audio DAC project.
YouTube Channel: https://www.youtube.com/user/sdgelectronics/
Use code: “SDG5” to get 5% off JBC Equipment at Kaisertech
Offline linux-works
    • netstuff
Re: S/PDIF Chip
« Reply #5 on: April 23, 2015, 07:25:46 am »
fwiw, my completed spdif switch
someday, I'll have better switch 'fabric' but this eval board gets the job done in the meantime.
