Hello, I want to transfer the 1pps and 10Mhz timing signals from a GPS receiver over fiber. Could I convert the single-ended timing signals to differential CML and connect it directly to the Fiber Optic differential receive pins? I'm thinking about using the Cisco CWDM-SFP10G-1470-20 Compatible 10G CWDM SFP+ 1470nm 20km DOM Transceiver Module. At the destination could I recover the timing signals by converting the differential CML to singled-ended?
Thanks,
Joe
