Author Topic: Old Ricoh printer reusing the lcd  (Read 248 times)
Offline no_name03Topic starter
  • Country: hr
« on: January 17, 2025, 03:50:25 pm »
Hi there, I would like to reuse the electronic components of and old Ricoh Aficio MP C2031, more specifically the screen, which is and LCD (640x200) labeled SHARP, with part number  LM089HB1T02. I was unable to find any datasheet on the device, so I have no idea how to use this device. It has a flex cable with 17 pins and 2 wire cable for power (most probably). I'd like to use also the other components (some RICOH labeled chips there, for example MB87F4192), for which I also couldn't find any datasheets. Any help would be appreciated.
Offline DavidAlfa
