Author Topic: -55 to +125C, fixed 12V regulator, 24V input, about 200mA+  (Read 694 times)
Offline 741Topic starter
    • Circuit & PCB Design (small PCB quantities OK)
« on: December 02, 2024, 03:08:54 pm »
Hi
I'm needing to re-specify a 12V regulator, used to be LM7812CT on the existing design, but the minimum temperature is 0C for this.
SG7812A looks good - but only seems available from Microchip directly, (5k qty) or long lead times from Digikey etc.
Offline Jon_S
Re: -55 to +125C, fixed 12V regulator, 24V input, about 200mA+
« Reply #1 on: December 02, 2024, 05:01:30 pm »
Can you qualify? The SG7812AIG shows as $176.98 each on Microchip Direct for me, it's a Hi-Rel special.
How about the MC7812BTG? -40°C to 125°C rated and available from all the usual suspects at about 50p in 1-off.
I would strongly suspect it will work absolutely fine. You are still well within the storage temperature, and the output voltage vs temp graph in the datasheet doesn't seem to show a hint of anything interesting starting to happen down to -40°C.
The following users thanked this post: 741
« Reply #2 on: December 02, 2024, 06:26:12 pm »
I did not realise it cost that much (!)
I'll take a look at the part you mentioned, thank you.
Offline rhodges
  • Available for embedded projects.
    • My public libraries, code samples, and projects for STM8.
« Reply #3 on: December 03, 2024, 01:01:05 am »
Aside from the startup, did you consider that dissipating 2.5 watts would keep it warm?
Currently developing embedded RISC-V. Recently STM32 and STM8. All are excellent choices. Past includes 6809, Z80, 8086, PIC, MIPS, PNX1302, and some 8748 and 6805. Check out my public code on github. https://github.com/unfrozen
Online Zero999
  • 0999
« Reply #4 on: December 03, 2024, 09:42:56 am »
Is this a new design or replacement?
If it's a new design, use the RH117 or LM117 (an LM317 but with a wider temperature range) & a couple of resistors.
Note, that once you specifiy things like extreme temperatures, you tend to get military grade devices which aren't cheap.
https://www.mouser.co.uk/c/semiconductors/power-management-ics/voltage-regulators-voltage-controllers/linear-voltage-regulators/?series=LM117&srsltid=AfmBOopi4YbFvRjcJ15QsJvUJQLuezD5t6XcsJf-UHk7AVYN8DJACqq8
Online peter-h
« Reply #5 on: December 03, 2024, 05:03:00 pm »
In most cases where you want this (milspec) temp range, you have to use parts which have this on their data sheet. Whether another one will actually work is totally irrelevant.
This leads to all kinds of absolutely hilarious situations on those industries e.g. in avionics you find the crappiest servo motors in autopilot servos - because the motor comes with that spec.
For a one-off one often finds milspec parts on Ebay. For production, you will have to pay ;) Power ICs are usually metal can. Some are TO3 but sometimes they are the centre-stud versions at exotic prices, often used in satellites. Most discrete parts are fine on this temp range, in plastic.
If you get stuck, get a power transistor, NPN, say TIP121 (-65C to +150C), put a 14V zener at its base, 1 resistor to put a few mA through the zener, and if the not-stellar load regulation is OK, there's a legal solution :) Cost will be pennies. A lot of people build their own circuits like this, to get the legit temp range. I've just done precisely this (24 to 12V) for an application where there are sizeable spikes which a 78xx reg will never take.
Offline SiliconWizard
« Reply #6 on: December 03, 2024, 10:18:42 pm »
Those extended temp range parts are expensive and relatively few. You can consider the LT3086M, which is around $10-$12, expensive for a linear reg but nowhere near the $100+ mark.
Online peter-h
« Reply #7 on: December 04, 2024, 01:26:11 pm »
I'd regard the LT3086M as way too off the wall. No way to replace it if you can't get it. But it is targeted at the milspec market allright so probably ok.
Offline youngda9
« Reply #8 on: December 04, 2024, 04:46:55 pm »
Scroll to the bottom of the link.  Digi-Key lists a bunch of drop-in replacements, many with the same base part number.
https://www.digikey.com/en/products/detail/onsemi/LM7812CT/1923051#product-details-substitutes
MC78M12BTG has the same temp range as the part being replaced.
Online Zero999
  • 0999
« Reply #9 on: December 04, 2024, 04:50:13 pm »
Testing is a possibility, but it incurs costs of its own and you need access to a suitable environmental test chamber. I've done it myself, when I worked at a defence contractor. Fortunately it had all equipment, otherwise it would have been expensive to rent one.
No it doesn't. The minimum operating temperature is −40°C, rather than −55°C specified in the original post.
« Last Edit: December 04, 2024, 07:15:21 pm by Zero999 »
