I have an odd issue with distortion on a high-frequency digital signal. The attached scope shot shows two complimentary clocks. I'm concerned with the rise time on the green signal.
Both simply have a 15-ohm series resistor leading to the input gate on the destination. The cable is about six inches long.
The device seems to be functioning as expected, but I just don't like the way that it looks. It makes me feel that this "working" may be a fringe case and that, in volume, the device will not function a good percentage of the time.
The signal is a -8V to 3V clock originating from a MAX627 MOSFET driver. I'm using this driver as a level shifter due to the required negative voltage swing.
Any tips?
