Author Topic: Driving 3-phase motor from 2 amplifier phases  (Read 3677 times)
Offline Benta
Re: Driving 3-phase motor from 2 amplifier phases
« Reply #25 on: December 28, 2018, 03:39:37 pm »
Are BLDC motors typically permanent magnet motors or squirrel cage?
BLDC motors always have permanent magnets inside.
Not necessarily. Larger types may have field windings. Those are rare, though.
Offline Dave
  • Country: si
  • I like to measure things.
« Reply #26 on: December 28, 2018, 05:19:00 pm »
Could you please provide an example of such motor?
To my understanding, you can't have a field winding on the rotor without having some sort of brushes in place to transfer the current onto the spinning rotor, therefore it would not be a brushless motor anymore (BLDC).
<fellbuendel> it's arduino, you're not supposed to know anything about what you're doing
<fellbuendel> if you knew, you wouldn't be using it
Offline Benta
« Reply #27 on: December 28, 2018, 05:36:57 pm »
The "brushless" part relates to commutation. Slip rings is another story.
It's a question of the classification of the motor.
Some automotive drives used this experimentally to cut cost, neodymium or cobalt-samarium magnets aren't cheap in the needed size.
Offline Zero999
  • 0999
« Reply #28 on: December 28, 2018, 05:58:31 pm »
Slip rings require brushes, so are not brushless.
There is really no such thing as brushless DC motor.
Offline jbb
« Reply #29 on: December 28, 2018, 06:45:35 pm »
I’m not sure if you’re using amplifiers to drive the motor for testing or for some kind of low noise operation, but I have an efficiency concern; I expect that the power factor on your two amplifiers could be quite bad under some conditions. This could lead to unexpectedly high dissipation in a Class B amp.
