Author Topic: Screwed up pfet SOT-23 design. Swapped Source and Drain  (Read 901 times)
Offline RibsterTopic starter
  • Electronics prototyper. Design. Prototype. Consult
    • Ash Labs
« on: December 20, 2019, 09:54:48 pm »
Hey everybody.
So what the title describes. I've swapped pin 2 and 3 of a SOT-23 pFET.
Respinning my boards would be a bit of a shame and wastefull.
I'm looking at some P MOSFETs that are like this: 1- GATE, 2 - DRAIN, 3 - SOURCE.
I've really screwed the pooch, since i now see that every one of them is DRAIN on pin 3...  :palm:
Suggestions ?
www.ashlabs.be
Design and manufacturing of embedded hard- and software
Offline T3sl4co1l
    • Seven Transistor Labs
Re: Screwed up pfet SOT-23 design. Swapped Source and Drain
« Reply #1 on: December 20, 2019, 10:47:54 pm »
If you have just a few, turn over the part and bend the leads down.  It'll be cocked at an angle.
An N-FET wouldn't short out the path, but you'd have to figure out some way to invert (and most likely boost) the gate voltage, which will be a tall order in most circuits.
Seven Transistor Labs, LLC
The following users thanked this post: Someone, thm_w, I wanted a rude username
Offline Someone
    • send complaints here
« Reply #2 on: December 21, 2019, 12:06:05 am »
Depends on how your pads are arranged/shaped, a different package (SC-70 for example) might fit as is.
    • Ash Labs
« Reply #3 on: December 21, 2019, 07:34:59 am »
I did just that and my design works as intended.
I just made 12 boards, and i want them to be ready for a client.
Thanks! I’ll have a look for SC-70 pinouts
www.ashlabs.be
