Author Topic: Screw/Fix PCB  (Read 1814 times)
Offline PerranOakTopic starter
Screw/Fix PCB
« on: June 19, 2019, 03:26:03 pm »
I need to screw (I guess) my battery holder (4xAAA) to my PCB.
The holder already has two countersunk holes of diameter 3.2mm.
What is the normal was to do it? Is the best solution to have a hole put in the PCB then use a self-tapper or use some kind of tiny bolt?
Either way, what make/model of screw/bolt should I use?
Thanks.
You can release yourself but the only way to go is down!
RJD
Offline soldar
Re: Screw/Fix PCB
« Reply #1 on: June 19, 2019, 03:50:44 pm »
Countersunk M3 should work for the holder. Depending on the PCB material and the holding needs maybe it will get a grip on the board. If you can use a nut on the other side that solves it.
And you can always use glue.
Offline Benta
Re: Screw/Fix PCB
« Reply #2 on: June 19, 2019, 04:11:05 pm »
Self tapping M3 into a non-plated 2.6 mm hole in the PCB (provided it's FR-4).
Re: Screw/Fix PCB
« Reply #3 on: June 19, 2019, 05:37:18 pm »
Cheers both.
FR-4?
RJD
Offline mdszy
  • somehow has an ee degree
    • szy.io
Re: Screw/Fix PCB
« Reply #4 on: June 19, 2019, 07:08:49 pm »
Cheers both.
FR-4?
FR-4 is the fiberglass material that most PCBs are made out of.
somehow allowed to be a Pixie Wrangler in Training
eBay Store | My site | Hackaday.io Projects | my mastodon.technology profile
Offline Benta
Re: Screw/Fix PCB
« Reply #5 on: June 19, 2019, 07:09:29 pm »
FR-4 is the term for the ubiquitous green fibreglass/Epoxy PCB material. My apologies for being "nerdy" here.
Offline Bud
Re: Screw/Fix PCB
« Reply #6 on: June 19, 2019, 08:13:21 pm »
I would not go with self tapping screws. Batteries are heavy, chances are good the screws will become lose with time and the holder will fall off. A countersink head screw and nut on the other side and perhaps a drop of threadlocking compound.
Re: Screw/Fix PCB
« Reply #7 on: June 19, 2019, 08:22:30 pm »
I’d put down a pad with a big annular ring or a suitably sized hole depending on your preference and put a shake proof washer and nut on the bottom with an M3 countersunk scree through it all.
Offline Benta
Re: Screw/Fix PCB
« Reply #8 on: June 19, 2019, 08:46:06 pm »
My apologies. I used the wrong term.
What I actually meant was "thread cutting screw", thus my reference to M3.
Like these:
https://www.valuefastener.com/screws/thread-cutting-screws
They hold excellently in 1.6 mm FR-4, and 4 x AAA ain't heavy.
« Last Edit: June 19, 2019, 08:48:10 pm by Benta »
Re: Screw/Fix PCB
« Reply #9 on: June 21, 2019, 01:24:14 pm »
Thank you all very much.
RJD
