I'm interested in the sensitivity of the cheap-as-chips SDR dongles containing an R802T2 tuner and RTL2832U demodulator. Since my principal interest is in wideband spectrum and network analysers, I don't care about the demodulator and am using the simple "rtl_power" application under Lnux
If I drive the input with a wideband white noise source, then in an ideal world, rtl_power would show a horizontal line across the 25-1500MHz band. Naturally it isn't like that, but there are some peculiar features I'd like to understand. The frequency domain sensitivity is shown in the attachment. The principal curious features are the "wiggle" between 1050 and 1150MHz, and the sharp 5dB transitions below 400MHz. Neither are level dependent, and they are visible in both rtl_power and gqrx applications.
I'm guessing the 1.1GHz "wiggle" is due to some anti-resonance effect associated with the R802T2 tuner or layout.
The sharp 5dB transitions, e.g. at 246.2MHz, are more troubling. They occur between adjacent FFT bins, even if the bins are only 1kHz wide. They appear to be related to the RF filter and/or mixer, since the voltage measured at the mixer's power detector output (pdet2, pin 5) also shows a sharp transition at the same frequency. (The 1.1GHz wiggle is also visible at the pdet2 output).
So, any comments on what might be the cause and/or cure?
Thanks
