Hello,
I'm trying to setup a SPI trigger on the first bit of the MISO signal (purple). It seems to only trigger on the last bit. The screenshot shows the trigger staying in the same position regardless of the Bit Pos 0 or Bit Pos 7 setting.
Am I using the trigger settings correctly here? I've double check the signal mappings are correct as is the Bit Order. They match my Decode settings which are correctly decoding the values being sent over the wire.
