another post about power supplies.
I have this Acus amplifier
https://www.acus-sound.it/en/one-forstreet/24-oneforstreet-8.html which comes from Europe that I'd like to convert to work on 120V.
This should be as simple as swapping the power transformer for a 120V primary with the same rating, right?
The original is primary 230V, secondary 16VAC, 128VA
The voltage regulator is an LM2937 12V, so I suppose a 15V 120VA transformer would do.
Assuming my plan is right, the problem I am left with is finding a transformer with the right dimension to fit in. All transformers I found online where more the flat type, i.e. larger and less high. I also tried contacting Acus but they haven't replied. And the company that build these transformer cannot be found on the internet.
Dimensions are : dia 80mm, height 70mm with hardware.
Where can I find one?
