Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
L and Resistor R function in a SMPS output nearby/vicinity
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: L and Resistor R function in a SMPS output nearby/vicinity (Read 472 times)
abdulbadii
Frequent Contributor
Country:
on:
January 19, 2023, 03:35:53 am »
What is the Inductor L and Resistor R function in a SMPS output vicinity below after transformer T output ?
What are the two values supposed to be calculated with respect to each other and to the two capacitors i.e. C1 and C2||C3 ?
SMPS rated as output 24V max 2.5 A
Please help elaborate the real mechanism crystal clearly !
Last Edit: January 19, 2023, 04:48:25 am by abdulbadii
Logged
T3sl4co1l
Super Contributor
Country:
Expert, Analog Electronics, PCB Layout, EMC
Re: L and Resistor R function in a SMPS output nearby/vicinity
Reply #1 on:
January 19, 2023, 04:05:55 am »
Impossible to tell without more design information; what output, what transformwer[sic]?
If this is like the output of a flyback, probably the L and C provide additional filtering, maybe the R is a leakage path so it discharges when off?
Logged
Seven Transistor Labs, LLC
Bringing a project to life? Send me a message!
Terry Bites
Super Contributor
Country:
Recovering Electrical Engineer
Reply #2 on:
January 20, 2023, 03:34:58 pm »
I think it would be helpful to look at a mirror image of this diagram. Its conventional to show signal and power flowing from left to right.
A rectifier feeding into a smoothing cap and a pi section LC filter is a very common configuration.
see
https://electronicscoach.com/pi-filter.html
L and C values are chosen to obtain the desired attenuation of the switching frequency.
I imagine the resistor creates a small load current.
Regulators will often not function correctly below a minimum load current.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
