SMPS freq
20khz ?50?100?
1 MHz 10mhz?
For a 120/240 mains the SMPS switches have 360V peak.
most DVM are for mains frequency 50/60hz, the detection is designed to work to perhaps 1 kHz.
Finally making any test, debugging an off-line SMPS requires scope, isolation transformers, current probes.
Your post suggests that your experience is not sufficient for this kind of work.
Jon
