Electronics => Projects, Designs, and Technical Stuff => Topic started by: ziplock9000 on June 10, 2020, 05:45:58 pm
Title: Sellers of ESP-01's with deep sleep RSP/XPD_DCDC pins already soldered?
Post by: ziplock9000 on June 10, 2020, 05:45:58 pm
I've been trying to solder the RST and XPD_DCDC pins on the cheap ESP-01's I have and I've found it impossible after several attempts. It's just too small even under magnification for me and the equipment I have.
Does anyone know anywhere that sells these already soldered and with AT firmware installed?
I tried using an ESP-03 which is easier to solder these pins together, but it just simply would not flash the firmware after screwing will all sorts of pins and trying different setups.
Thanks.
