I've been trying to solder the RST and XPD_DCDC pins on the cheap ESP-01's I have and I've found it impossible after several attempts. It's just too small even under magnification for me and the equipment I have.
Does anyone know anywhere that sells these already soldered and with AT firmware installed?
I tried using an ESP-03 which is easier to solder these pins together, but it just simply would not flash the firmware after screwing will all sorts of pins and trying different setups.
Thanks.
