Hi guys and girls,
New forum user here, but a big fan of the show. In fact I got my idea for this project from a video Dave had about the 6W standby power on the InfiniiVision scopes. I guess I'm another one of those people who waits to make an account until the very moment they need a life raft.
Well, I'm a senior majoring in electronic engineering technology which means I've been working on a final design project. I thought I had the project going smoothly until I hit a bit of a road block earlier this week. I've come to you all to ask for any help which might get me back on track.
My project is called the power saving adapter. The idea is to take any appliance with high standby power (also called phantom power) and reduce it as much as possible. I designed a circuit which would do this by switching in 12Vac instead of 120Vac when the appliance is turned off. That way the voltage would be reduced by a factor of 10, the current by a factor of 10, and the power (hopefully) by a factor of 100.
Of course theory never matches up to reality and I'm now realizing that this idea does not seem hopeful. Let me just elaborate on the functioning of the circuit a bit to make my problem more clear. An appliance (let's say an electric heater) is plugged into my project, and then my project is plugged into the wall. The heater is then turned off. Now there is a current sensor in series with the heater. A push button is connected to a microcontroller which stores the value from the current sensor into the memory of the micro. So the "off" current of the heater is now stored in memory. Whenever the microcontroller is reading the value of the heater current to be equal to the value of the "off" current, 12V is switched in, and power is now being saved in the heater's standby mode. Now when the user turns the heater on, there will be an increase in current. The microcontroller sees this increase in current which then switches 120V back in so the heater functions normally. Make sense?
Well, I stupidly waited several months to test my idea of feeding an appliance 12V. As I should have guessed, the appliance makes no attempt to turn on when it is only given 12V. There is no increase in current at all. Without that increase, there is no way to tell the microcontroller to switch back to 120V.
If anyone's curious here's what the circuit looks like:
So, I'm not sure what to do next really. Shit-canning the whole project isn't an option. I was wondering if there's some kind of chip which I could put in series with the output of the transformer which would somehow limit the current and not dissipate much power. That way I could still send 120V to the load, but at a much lower current. Maybe some kind of transistor configuration?
Anyway, thanks to anyone who reads this and has any kind of suggestions at all. All replies are welcome. If you would like me to elaborate on anything just let me know.
Cheers!
