Ok, here I'm with some news.
I got the picture from my friend abhout the "CDI".
His "CDI" is also unusable cos some part's are missing but however, maybe we can figure out something.
Based on the information I got from the engine and the picture I come to a conclusion:
This ignition coil on this engine is a 3 pin coil.
pin 1 and 2 are the primary coil
pin 3 is the HV wire to the spark plug.
The mentioned "CDI" is not a CDI, I don't know what is the correct name of this ignition controller but it is not a CDI.
Based on this I think I have to make a kind of controller with a MOSFET which is switching the primari side of the ignition coil,
depending when the TDCS ( Top Death Center Sensor ) triggers the momentum whebn the piston is on it's top death position.
I also assume I need to rectifie the AC voltage from the "exciting" coil, cos that coil is not a real exciting coil,
it is actually the power source to power.
Description of the PCB from the picture:
Pin 1 is directly connected to the pin 1 on the ignition coil.
Pin 2 is the oil level swithch which is in open stage if the oil level is ok, othervice it is shorted to ground.
Pin 3 is the TDCS sensor. The TDCS is a two wire sensor. One end is on the gnd and the other is on PIN 3.
Pin 4 is connected to the engine housung which is gnd.
Pin 5 is one wire from the "exciting" coil, this is actually a AC voltage source to power the electronic ignition coil controller.
Pin 6 is the kill switch.
The picture from the scope is the signal when I pull the rope and the motor start to rotate and the piston is always in the TD center when I have this signal.
So, I have to collect somehow the TDCS signal and trigger the MOSFET.
Question:
1. Is it enough to collect the positive signal side of the TDCS?
2. any example or idea how to proccess the signal I would really appreciate.
Thank you for any help and/suggestion.
