Monitor for the 12V circuit, the Jfet is normally pinched hard off if the 12V is present, but if it is not there the Jfet turns on, pulling the comparator input to below the reference voltage, and thus pulling the output low. Little bit of hysteresis provided by R42, R43 and C28, so it switches cleanly as the voltage on the Jfet gate drops, as it has a RC filter on it that takes roughly 80 seconds to either charge or discharge, so the microcontroller can see, based on the state of the pin at power up, so if it takes roughly 2 minutes to go high, it is the load management unit, and if it is high on power on, or after roughly a second, it is a field test unit. Likely they all power up as field test for 2 minutes or so, before changing operation mode, probably to allow for calibration or adjustment.
