Code was too long so here is the rest
:: The tests OPSO, OQSO and DNA ::
:: OPSO means Overlapping-Pairs-Sparse-Occupancy ::
:: The OPSO test considers 2-letter words from an alphabet of ::
:: 1024 letters. Each letter is determined by a specified ten ::
:: bits from a 32-bit integer in the sequence to be tested. OPSO ::
:: generates 2^21 (overlapping) 2-letter words (from 2^21+1 ::
:: "keystrokes") and counts the number of missing words---that ::
:: is 2-letter words which do not appear in the entire sequence. ::
:: That count should be very close to normally distributed with ::
:: mean 141,909, sigma 290. Thus (missingwrds-141909)/290 should ::
:: be a standard normal variable. The OPSO test takes 32 bits at ::
:: a time from the test file and uses a designated set of ten ::
:: consecutive bits. It then restarts the file for the next de- ::
:: signated 10 bits, and so on. ::
:: OQSO means Overlapping-Quadruples-Sparse-Occupancy ::
:: The test OQSO is similar, except that it considers 4-letter ::
:: words from an alphabet of 32 letters, each letter determined ::
:: by a designated string of 5 consecutive bits from the test ::
:: file, elements of which are assumed 32-bit random integers. ::
:: The mean number of missing words in a sequence of 2^21 four- ::
:: letter words, (2^21+3 "keystrokes"), is again 141909, with ::
:: sigma = 295. The mean is based on theory; sigma comes from ::
:: extensive simulation. ::
:: The DNA test considers an alphabet of 4 letters:: C,G,A,T,::
:: determined by two designated bits in the sequence of random ::
:: integers being tested. It considers 10-letter words, so that ::
:: as in OPSO and OQSO, there are 2^20 possible words, and the ::
:: mean number of missing words from a string of 2^21 (over- ::
:: lapping) 10-letter words (2^21+9 "keystrokes") is 141909. ::
:: The standard deviation sigma=339 was determined as for OQSO ::
:: by simulation. (Sigma for OPSO, 290, is the true value (to ::
:: three places), not determined by simulation. ::
:: This is the COUNT-THE-1's TEST on a stream of bytes. ::
:: Consider the file under test as a stream of bytes (four per ::
:: 32 bit integer). Each byte can contain from 0 to 8 1's, ::
:: with probabilities 1,8,28,56,70,56,28,8,1 over 256. Now let ::
:: the stream of bytes provide a string of overlapping 5-letter ::
:: words, each "letter" taking values A,B,C,D,E. The letters are ::
:: determined by the number of 1's in a byte:: 0,1,or 2 yield A,::
:: 3 yields B, 4 yields C, 5 yields D and 6,7 or 8 yield E. Thus ::
:: we have a monkey at a typewriter hitting five keys with vari- ::
:: ous probabilities (37,56,70,56,37 over 256). There are 5^5 ::
:: possible 5-letter words, and from a string of 256,000 (over- ::
:: lapping) 5-letter words, counts are made on the frequencies ::
:: for each word. The quadratic form in the weak inverse of ::
:: the covariance matrix of the cell counts provides a chisquare ::
:: test:: Q5-Q4, the difference of the naive Pearson sums of ::
:: (OBS-EXP)^2/EXP on counts for 5- and 4-letter cell counts. ::
:: This is the COUNT-THE-1's TEST for specific bytes. ::
:: Consider the file under test as a stream of 32-bit integers. ::
:: From each integer, a specific byte is chosen , say the left- ::
:: most:: bits 1 to 8. Each byte can contain from 0 to 8 1's, ::
:: with probabilitie 1,8,28,56,70,56,28,8,1 over 256. Now let ::
:: the specified bytes from successive integers provide a string ::
:: of (overlapping) 5-letter words, each "letter" taking values ::
:: A,B,C,D,E. The letters are determined by the number of 1's, ::
:: in that byte:: 0,1,or 2 ---> A, 3 ---> B, 4 ---> C, 5 ---> D,::
:: and 6,7 or 8 ---> E. Thus we have a monkey at a typewriter ::
:: hitting five keys with with various probabilities:: 37,56,70,::
:: 56,37 over 256. There are 5^5 possible 5-letter words, and ::
:: from a string of 256,000 (overlapping) 5-letter words, counts ::
:: are made on the frequencies for each word. The quadratic form ::
:: in the weak inverse of the covariance matrix of the cell ::
:: counts provides a chisquare test:: Q5-Q4, the difference of ::
:: the naive Pearson sums of (OBS-EXP)^2/EXP on counts for 5- ::
:: and 4-letter cell counts. ::
:: THIS IS A PARKING LOT TEST ::
:: In a square of side 100, randomly "park" a car---a circle of ::
:: radius 1. Then try to park a 2nd, a 3rd, and so on, each ::
:: time parking "by ear". That is, if an attempt to park a car ::
:: causes a crash with one already parked, try again at a new ::
:: random location. (To avoid path problems, consider parking ::
:: helicopters rather than cars.) Each attempt leads to either ::
:: a crash or a success, the latter followed by an increment to ::
:: the list of cars already parked. If we plot n: the number of ::
:: attempts, versus k:: the number successfully parked, we get a::
:: curve that should be similar to those provided by a perfect ::
:: random number generator. Theory for the behavior of such a ::
:: random curve seems beyond reach, and as graphics displays are ::
:: not available for this battery of tests, a simple characteriz ::
:: ation of the random experiment is used: k, the number of cars ::
:: successfully parked after n=12,000 attempts. Simulation shows ::
:: that k should average 3523 with sigma 21.9 and is very close ::
:: to normally distributed. Thus (k-3523)/21.9 should be a st- ::
:: andard normal variable, which, converted to a uniform varia- ::
:: ble, provides input to a KSTEST based on a sample of 10. ::
:: THE MINIMUM DISTANCE TEST ::
:: It does this 100 times:: choose n=8000 random points in a ::
:: square of side 10000. Find d, the minimum distance between ::
:: the (n^2-n)/2 pairs of points. If the points are truly inde- ::
:: pendent uniform, then d^2, the square of the minimum distance ::
:: should be (very close to) exponentially distributed with mean ::
:: .995 . Thus 1-exp(-d^2/.995) should be uniform on [0,1) and ::
:: a KSTEST on the resulting 100 values serves as a test of uni- ::
:: formity for random points in the square. Test numbers=0 mod 5 ::
:: are printed but the KSTEST is based on the full set of 100 ::
:: random choices of 8000 points in the 10000x10000 square. ::
:: THE 3DSPHERES TEST ::
:: Choose 4000 random points in a cube of edge 1000. At each ::
:: point, center a sphere large enough to reach the next closest ::
:: point. Then the volume of the smallest such sphere is (very ::
:: close to) exponentially distributed with mean 120pi/3. Thus ::
:: the radius cubed is exponential with mean 30. (The mean is ::
:: obtained by extensive simulation). The 3DSPHERES test gener- ::
:: ates 4000 such spheres 20 times. Each min radius cubed leads ::
:: to a uniform variable by means of 1-exp(-r^3/30.), then a ::
:: KSTEST is done on the 20 p-values. ::
:: This is the SQEEZE test ::
:: Random integers are floated to get uniforms on [0,1). Start- ::
:: ing with k=2^31=2147483647, the test finds j, the number of ::
:: iterations necessary to reduce k to 1, using the reduction ::
:: k=ceiling(k*U), with U provided by floating integers from ::
:: the file being tested. Such j's are found 100,000 times, ::
:: then counts for the number of times j was <=6,7,...,47,>=48 ::
:: are used to provide a chi-square test for cell frequencies. ::
:: The OVERLAPPING SUMS test ::
:: Integers are floated to get a sequence U(1),U(2),... of uni- ::
:: form [0,1) variables. Then overlapping sums, ::
:: S(1)=U(1)+...+U(100), S2=U(2)+...+U(101),... are formed. ::
:: The S's are virtually normal with a certain covariance mat- ::
:: rix. A linear transformation of the S's converts them to a ::
:: sequence of independent standard normals, which are converted ::
:: to uniform variables for a KSTEST. The p-values from ten ::
:: KSTESTs are given still another KSTEST. ::
:: This is the RUNS test. It counts runs up, and runs down, ::
:: in a sequence of uniform [0,1) variables, obtained by float- ::
:: ing the 32-bit integers in the specified file. This example ::
:: shows how runs are counted: .123,.357,.789,.425,.224,.416,.95::
:: contains an up-run of length 3, a down-run of length 2 and an ::
:: up-run of (at least) 2, depending on the next values. The ::
:: covariance matrices for the runs-up and runs-down are well ::
:: known, leading to chisquare tests for quadratic forms in the ::
:: weak inverses of the covariance matrices. Runs are counted ::
:: for sequences of length 10,000. This is done ten times. Then ::
:: repeated. ::
:: This is the CRAPS TEST. It plays 200,000 games of craps, finds::
:: the number of wins and the number of throws necessary to end ::
:: each game. The number of wins should be (very close to) a ::
:: normal with mean 200000p and variance 200000p(1-p), with ::
:: p=244/495. Throws necessary to complete the game can vary ::
:: from 1 to infinity, but counts for all>21 are lumped with 21. ::
:: A chi-square test is made on the no.-of-throws cell counts. ::
:: Each 32-bit integer from the test file provides the value for ::
:: the throw of a die, by floating to [0,1), multiplying by 6 ::
:: and taking 1 plus the integer part of the result. ::
NOTE: Most of the tests in DIEHARD return a p-value, which
should be uniform on [0,1) if the input file contains truly
independent random bits. Those p-values are obtained by
p=F(X), where F is the assumed distribution of the sample
random variable X---often normal. But that assumed F is just
an asymptotic approximation, for which the fit will be worst
in the tails. Thus you should not be surprised with
occasional p-values near 0 or 1, such as .0012 or .9983.
When a bit stream really FAILS BIG, you will get p's of 0 or
1 to six or more places. By all means, do not, as a
Statistician might, think that a p < .025 or p> .975 means
that the RNG has "failed the test at the .05 level". Such
p's happen among the hundreds that DIEHARD produces, even
with good RNG's. So keep in mind that " p happens".
