Author Topic: Set of four TL866II-Plus programmer stopped working  (Read 3355 times)
Offline CirclotronTopic starter
« on: February 17, 2024, 10:44:43 am »
I have a set of four TL866II-Plus programmers running off my Linux Mint pc and for several years everything has been working okay. Just tonight they have all stopped working. The programming software was bugging me to update it so I did but no improvement. It is now version 12.66
The individual programmers are TL866II-Plus Ver: 04.02.132
The PC recognises them as being connected. Used USBview.
Xingong XGecu USB Prog.. Device
Manufacturer: Xingong Electronicg Co..
Speed: 12Mb/s (full)
Bus:   1
Address:  57
USB Version:  2.00
Device Class: 00(>ifc )
Device Subclass: 00
Device Protocol: 00
Maximum Default Endpoint Size: 8
Number of Configurations: 1
Vendor Id: a466
Product Id: 0a53
Revision Number:  0.00
Config Number: 1
Number of Interfaces: 1
Attributes: c0
MaxPower Needed: 100mA
Interface Number: 0
Alternate Number: 0
Class: ff(vend.)
Sub Class: ff
Protocol: ff
Number of Endpoints: 6
Endpoint Address: 01
Direction: out
Attribute: 2
Type: Bulk
Max Packet Size: 64
Interval: 0ms
Endpoint Address: 81
Direction: in
Attribute: 2
Type: Bulk
Max Packet Size: 64
Interval: 0ms
Endpoint Address: 02
Direction: out
Attribute: 2
Type: Bulk
Max Packet Size: 64
Interval: 0ms
Endpoint Address: 82
Direction: in
Attribute: 2
Type: Bulk
Max Packet Size: 64
Interval: 0ms
Endpoint Address: 03
Direction: out
Attribute: 2
Type: Bulk
Max Packet Size: 64
Interval: 0ms
Endpoint Address: 83
Direction: in
Attribute: 2
Type: Bulk
Max Packet Size: 64
Interval: 0ms
I remember some time ago I had to reflash the programmers after upgrading the software but I can't remember how I did it.
Actually if I disconnect and reconnect the programmers multiple times the software eventually sees them, but if I run Tools / System Self check it comes up with VPP Testing... Write device error.
What should I do now?
Edit -> They *seem* to be running okay in Win7 in VirtualBox.
« Last Edit: February 17, 2024, 10:51:56 am by Circlotron »
Offline retiredfeline
Re: Set of four TL866II-Plus programmer stopped working
« Reply #1 on: February 17, 2024, 10:57:44 am »
If you are trying all of them from one PC then I think the PC is the more likely suspect? Try another PC?
Offline jonpaul
« Reply #2 on: February 17, 2024, 11:29:01 am »
ChiCom form XGeu has history of "bricking" working products with a FW "upgrade"
Try to flash back one FW rev earlier.
j
Jean-Paul  the Internet Dinosaur
Offline pienari
« Reply #3 on: February 17, 2024, 11:59:00 am »
Windows driver issue.
« Reply #4 on: February 17, 2024, 12:19:28 pm »
As above, they work okay on Win7 in VirtualBox on the same PC, so the issue lies entirely with Linux.
Update -> tried it once again on Linux after doing 40 eproms on win7 and the darn things work just fine now...  :palm:  Previously when I ran I run Tools / System Self check it would come up with "VPP Testing... Write device error" but now it checks out okay.
« Last Edit: February 17, 2024, 12:26:23 pm by Circlotron »
