It is coming along, I had a few setbacks and a meltdown today with it. I was fixing a leak in the system and fired it up without the cooling system active, the result was a cracked tube. There was water in the cooling jacket, but it only covered half the tube. The tube has been replaced, the epoxy is now curing for another go. For the few moments it was on today, it did create a beam, which hit a block of wood I had sitting in front of it
So, I know it works. The gas I used was a mix of nitrogen, co2, and helium.
This is the third tube that I have replaced. The others were due to either too much tension on the optics or flaws in the glass.
I am considering doing a complete redesign on it for my next build. Right now, it really isn't the safest laser out there.
What would I do different?
1. totally separate the gas in/out from the electrodes. For simplicity, this one used a simple sharkbite fitting, and to get power into the system you simply clip the power supply onto each end.
2. I would probably go with a larger diameter tube for the laser itself, this one is ok, but I think I can do better
3. I would build the cooling jacket out of plexiglass/lexan instead of pvc.... save the hastle of using a window, and give it a square profile.... this isn't a huge thing, more aesthetics than anything.
I will post up a video as soon as I get it working... "reliably" :> a.k.a. not blowing up due to overheating.
Yeah, I know I should date the posts on the website.
The first firing I did get a picture of, as you can see, there is a leak in the system and it took a bit of work to find out exactly where and how to fix it without a total rebuild. Turns out it was in the OC optics.... and an additional gasket fixed it.
This was with no gas, just firing it up to see if the tube would glow... with a proper vacuum, it should be pink, not purple.
As soon as the epoxy cures properly, I will give it another go... this time with video recording, just in case
