Author Topic: Power Supply for Jim Williams Pulse Generator  (Read 3143 times)
Offline BryanTopic starter
« on: July 28, 2015, 07:06:46 am »
Hello:
Would someone mind looking over the schematic for the power supply for the Jim Williams Pulse Generator. I am wondering what size of inductor is needed?. Was thinking of using a single 1.5v cell.   Cheers
http://www.kerrywong.com/2013/05/18/avalanche-pulse-generator-build-using-2n3904/
-=Bryan=-
Offline Warhawk
    • Personal resume
Re: Power Supply for Jim Williams Pulse Generator
« Reply #1 on: July 28, 2015, 07:17:54 am »
Hi, on the picture below the schematic diagram there is TV1415-B inductor used.
It should be 22uH 2.5 inductor.
It is a strange coding explained here: http://electronics.stackexchange.com/questions/50582/help-reading-inductor-label
Cheers
Jiri
« Reply #2 on: July 28, 2015, 07:35:12 am »
Thanks, I wonder if the inductor value is dependent on the input voltage. The author used a 4.5v supply where I wanted to use 1.5v. Maybe it doesn't matter?.
-=Bryan=-
Offline Warhawk
    • Personal resume
« Reply #3 on: July 28, 2015, 08:11:07 am »
Let's have a look at it. It is a step-up converter with boosted output. In general, the energy calculation for one period is:
(Energy-in) / (efficiency) = Energy-out
Energy-in is stored to the inductor only during ton phase.
Ein=1/2*L*Ipeak^2
and also Ipeak = Vin*ton/L
Combining those two formulas gives me
Ein=Vin2*ton2/2*L
Long story short, low input voltage must be compensated by longer ton or smaller inductor to keep output energy (power) constant. The IC chip by himself can work from 1.1V.
If I were you I would start with the specified inductor.
I Better wondering why author took feedback from the first stage and not from the output like Jim previously did.
« Last Edit: July 28, 2015, 08:36:37 am by Warhawk »
« Reply #4 on: July 29, 2015, 01:14:35 am »
He explains in the blog as to the reasons why.
 Note that in Jim’s original HV circuit with LT1073, the feedback resistor was located at the HV output of the voltage multiplier, whereas in my circuit I left the feedback point at the primary output and leaving the multiplier voltage unregulated. The reason for this decision is that should R2 become unconnected the voltage input to the feedback pin will remain be within tolerance, avoiding any possible damage to the chip. Also, since the current requirement for the avalanche pulse generator is very low, regulating the HV output is not strictly necessary.
-=Bryan=-
Offline Warhawk
    • Personal resume
« Reply #5 on: July 29, 2015, 06:09:01 am »
I should have read it first ::)
Thanks
