Hi everyone,
I’m working on a very compact PCB design that includes a shielded inductor from a 24V SMPS located close to an ideal diode controller circuit. The minimum clearance between the edge of the inductor and the nearest component in the ideal diode controller circuit is approximately 4mm.
The SMPS boosts 12V to 24V with an output current of around 2A. While I’m aware that magnetic shielding in fully encapsulated inductors is highly effective, I’ve had to position the components closer than I’d like due to space constraints on the board.
The PCB is an 8-layer stackup with multiple ground planes. Any longer traces that must be routed near the inductor are placed on internal layers, sandwiched between at least one ground plane above and below for added shielding.
Does anyone have insights or guidelines on the recommended clearance for shielded inductors in such scenarios? Most of the resources I’ve found seem a bit ambiguous on this topic.
I’ve attached a screenshot of the layout for reference.
Thanks!
