Author Topic: short range (<cm) full duplex IR data exhange?  (Read 3038 times)
Offline max_torqueTopic starter
    • bitdynamics
« on: April 14, 2019, 07:38:25 pm »
I've been looking at using infrared data exchange to effectively "Hide" an interface for a remote device, as the TX and RX diodes can be hidden behind a visible light blocking filter.  There are lots of off-the-shelf half duplex IR transcievers, some with built in emitters etc, but they are all reasonably slow, and always seem to "mirror" any TX back onto the RX output, i guess to avoid reflected IR from causing issues, and that means they are restricted to half duplex coms.  I'd really like full duplex at up to say 500kbps or something like that. This looks like it will need two different modulation frequencies and RX detectors that are a narrow pass at those different frequencies to be able to discriminate the TX's apart.
How hard is this likely to be?  Modulating the TX diode is trivial, and i can't see why a basic driver couldn't do that at around 2 Mhz or more?
The RX path is harder, requiring a band pass filter (a tuned/resonant filter makes some sense here i think) into a precision rectifier and then a comparitor to chop the bits out of the modulated stream.
The total transmission distance ca be very short, i'm currently thinking about a magnetically attached "probe" that just snaps into the correct place over the hidden TX and RX diode "window"
Anyone done something similar?   :scared:
Online jbb
Re: short range (<cm) full duplex IR data exhange?
« Reply #1 on: April 15, 2019, 12:10:56 am »
Well, there were the assorted IRDA standards.  They got nibbled at by Bluetooth for phone accessories and then eaten alive by WiFi.  But they did show that quite high data rates can be achieved.  In a nice example of "what was old is new again," people are now talking about LiFi (Light + WiFi) for ultra high speed LAN work.
I guess you could do some sort of on/off coding with an IR LED at 2 Mbit/s.  You would need some modulation to remove the DC and low frequency components of the data - maybe Manchester Encoding?  (Note: the receiver will experience DC drift and 50 / 60 / 100 / 120 Hz lighting flicker will absolutely be present somewhere.)
On the receive side, a photodiode => TransImpedance Amplifier (TIA) => band pass filter => comparator might work to recover the data stream.  You'd need something to decode it.
    • bitdynamics
« Reply #2 on: April 15, 2019, 07:09:09 am »
The diodes should be fairly well shielded from most ambient light when coms are operational, as the "probe" from the master will cover the diodes on the slave unit. I considered using a hall effect switch to sense the magnets on the probe and only try to establish coms when that switch is shut, and hence the system will ignore any spurious inputs when the ldr is uncovered?
Offline pwlps
« Reply #3 on: April 15, 2019, 09:27:56 am »
For RX the standard method is a PLL-based tone detection which is much more sensitive than any circuit based on band-pass filter (rejection of out-of-band signals is excellent with a PLL), and it isn't too difficult to make.  I tried it once in a somewhat similar project, using  the tone decoder chip LM567, it was quite simple to set up and worked well, however the chip is limited to 500kHz or so.   I don't know if equivalent chips exist for higher freqs.  I also played with another version using a 4046 PLL, then to make a tone decoder I needed to add a two D-flip-flop freq divider/quadrature generator and a second mixer (like in the LM567), this was a bit harder to set up but eventually worked too. There is also a new version of 4046, the 74HCT9046A, which goes to higher frequencies, but I didn't try it.
Offline jmelson
« Reply #4 on: April 16, 2019, 03:13:16 am »
I did an IR receiver using the QSE159 from Fairchild.  Part # QSE159 on Digi-Key.  I just used a bank of IR LEDs for the transmitter.
It worked very well, seems to be totally immune to visible light, and simple to use.  In my particular application, it was NOT a 40 KHz on-off modulated carrier, so I needed a sensor that did not depend on modulation.
Jon
« Last Edit: April 16, 2019, 03:15:01 am by jmelson »
Online jbb
« Reply #5 on: April 16, 2019, 08:13:46 am »
If you use a CRC check (sorry, reduncant acronym) then random environmental noise should get thrown out. However you might have too many interrupts to deal with...
A separate presence sensor is more to go wrong, but could be useful for simply disabling the IR path. Especially if your device is battery powered (receiver might be quite hungry).
Offline soldar
« Reply #6 on: April 16, 2019, 11:53:17 am »
If you are thinking of the two communicating units being pretty much touching then you could separate the two channels so you have one IR channel going one way and another IR channel going the other way.
Offline JVR
« Reply #7 on: April 16, 2019, 12:10:50 pm »
Why not just use RF?
    • bitdynamics
« Reply #8 on: April 16, 2019, 06:42:01 pm »
RF is out because of the specific environment this device is used in (sorry, i can't be too specific....)
I could arrange for the RX and TX channels to have two completely independent and separate optical paths, but it would be easier for them to share the same path, as that will remove any alignment issues and make for a smaller probe.  I'm going to have a play around with that LM567, and see what data rate i can robustly get within it's maximum 500KHz demodulation frequency.
Offline eliocor
    • rhodiatoce
« Reply #9 on: April 16, 2019, 08:33:14 pm »
to reduce crosstalk (full duplex) just use two different wavelenght transmitters (850nm and 940nm). Put on the receivers a comparable IR filter.
Offline langwadt
« Reply #10 on: April 16, 2019, 09:10:30 pm »
why do you need real full duplex? 500kbps isn't particularly fast, just do 1mbps and toggle between rx and tx
Offline pwlps
« Reply #11 on: April 17, 2019, 11:15:07 am »
If you need higher freqs you might also have a look at this app note from TI:
http://www.ti.com/lit/an/slaa618/slaa618.pdf
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #12 on: April 17, 2019, 11:19:48 am »
High speed IRDA works well but  all of the nice transceiver devices are obsolete now.4M and 16Mbit - Digikey only has stock left of this one
https://www.digikey.co.uk/product-detail/en/rohm-semiconductor/RPM973-H11E2A/RPM973-H11E2ACT-ND/3769159
Forget full-duplex - witha free-air link you will always get reflections -  if necessary ping-pong at a higher rate to get the same result
Day Job: Mostly LEDs
Offline JVR
« Reply #13 on: April 17, 2019, 12:04:16 pm »
I know the feeling. However, design is making the best compromises. Is having a 500Kbit link worth technician time and design/manufacturing issues? Or will a 100Kbit link do the same thing with off the shelf components, albeit a little slower.
Last resort would probably be inductive or capacitive comms, but both also have other issues you will need to solve for.
« Reply #14 on: April 17, 2019, 12:52:24 pm »
If you're basically going through a wall of a case then inductive may be a good choice, and doesn't need a window.
Unshielded drum style inductors placed on-axis a few mm apart couple very well - 500k might get tricky but 100k should be no problem.
    • bitdynamics
« Reply #15 on: April 17, 2019, 06:26:59 pm »
This is why i as looking at using a different TX and RX frequency in order to fully discriminate against cross talk   :-+
Offline langwadt
« Reply #16 on: April 17, 2019, 08:30:42 pm »
for light that would have to be different colors of light
Offline ogden
  • Country: lv
« Reply #17 on: April 17, 2019, 08:53:49 pm »
Very bad idea. You can discriminate crosstalk only by discriminating optical paths. Half duplex IRDA can reach TX/RX speeds you are looking for, so take it as it is. Consider that those who made IRDA knew what they are doing - they made it half-duplex for a very good reason.
Offline eliocor
    • rhodiatoce
« Reply #18 on: April 17, 2019, 09:49:32 pm »
If you want to use the same optical path, and mantain a full duplex communication, your only solution is using different IR light wavelengths: 850nm and 940nm, followed by optical filters on the receivers.
For your tests, start with known good one filters (expensive!):
https://www.edmundoptics.com/f/traditional-coated-700-1650nm-bandpass-interference-filters/13917/
once done, you can test with cheaper (but not always available and of [maybe] shady quality) ones, like:
https://www.aliexpress.com/item/940-Nm-Infrared-Narrowband-Filter-NBP940-Half-width-40-Nm-Bandwidth-8-8-0-55mm-0/32982732595.html
https://www.aliexpress.com/item/High-quality-IR-coated-film-filter-band-pass-850nm-laser-transmissivity-92-black-glass-filter-infrared/32864007904.html
If the bandwidth of your filters is too narrow, you have to take care about emitter wavelength shifts do to temperature changes
« Last Edit: April 17, 2019, 09:51:49 pm by eliocor »
Offline pwlps
« Reply #19 on: April 18, 2019, 04:41:16 pm »
The "only solution" is a bit exaggerated and discouraging for the OP's project.  The FSK demodulation bandwidth is controlled by the loop filter time constant so that there is a of course a tradeoff between the frequency selectivity and the maximum bitrate, in other words sacrifying the bitrate you can have as many FSK channels as you want in a single IR wavelength channel.
« Last Edit: April 18, 2019, 04:44:44 pm by pwlps »
Offline langwadt
« Reply #20 on: April 18, 2019, 09:20:38 pm »
doesn't help if a device's receiver is swamped out by its own transmitter
