Hi, all:
Are there any Dedicated engineers here? The kind that Build something, rather than following only what others say, and make an Arduino act like a 555 and some logic gates?
Sorry, that was TERRIBLY harsh, but not THAT long ago, Hacking was a way of life, not a weekend sidetrack to make some LEDs flash. We were ALWAYS on alert for stuff we could re-purpose, re-use, modify, adapt, or even outright DUPLICATE to achieve our OWN needs.
How DO factories strip wires?
It is often with expensive Thermal strippers, out of reach of many DIY engineers.
But taking an IDEA can educate and serve as a lesson in Principles that little else can.
Here are a few examples:
http://www.stanleysupplyservices.com/hakko-ft801-31-thermal-knife-blade-wirestripper-with-hot-knife-blades/p/477-915http://www.stanleysupplyservices.com/patco-pts-10-thermal-wire-strippers/p/118-866http://www.series4.co.uk/prodeqpt/section01/ds5.htmThat was 3, one listed under $100.00US, and there were Ideas Abundant in the photos and descriptions.
PLEASE don't whine that an ex-microwave-oven transformer, a few feet of heavy copper wire, some nichrome or iron wire (or, even Exotics, like Platinum or Tantalum), miscellaneous metal and insulating material fabricated pieces, a switch and perhaps relay or timer, and some good-old thinking and craftiness prices you out of the market: The hot wire should be the sole consumable, and a well-thought-out power circuit and Mechanical assembly should outlive the future use of copper wire and/or soldering.
Multiple methodologies and details are visible in those links, and any man or woman with a mind to Create should be able to make a Production-Quality stripper that NEVER nicks wire!
I wish you all the best of fortune!
HTH
Cheers,
Dave
