First all thanks too all who has answered my questions in the pass, has been a great help.
Now, I have another questions, probably basic for someone but not so much for me. I'll try to do this in a very academic style, could be helpful for others too.
I designed a
eC (electroconductivity) meter, and for thous who don't know what is that is the measurement of the conductivity of water with something dissolved (kid style explanation), through the measurement of the equivalent resistance of a probe inside of the solution.
My first design was a pure sine wave rectified with same wave through a probe in solution (rectified too), the difference is proportional to the impedance and from there I have my conductivity measurement. The data calculation and simulation are very close, getting a constant difference of 20mV in all range, and even that is not a problem because the calibration of the system should compensate that, better is that difference is constant.
The reason to use a sin wave in my first design is to void degradation on the probe.
The circuit (Image1) is big and expensive to get the resolution I want in my device.
Now, at side in my board I had designed a pH meter who use a
AD7793DAC, who have current outputs, each one can give 10uA, 210uA or 1mA. Now I'm taking a
AD7794 DAC with more inputs to add the eC meter and make use of the current outputs and void almost all the electronics showed behind.
¿ why a current source given the problems they have (probe degradation in contrast to sine waves) ?, because I can make a 4 point measurement, more precision on the readings, and at uA levels the degradation is very low, anyway I will test it.
The circuit is resumed on Image2.
Now, I'm very tempted to get the signal right from the probe and put it on to the
AD7794 differential inputs plus some filters but I'm not so sure if I need more signal conditioning there, I'm aware of the input current bias compensation but even with that I think the input impedance is not high enough and probably worth the effort to get a instrumentation amplifier.
The load is a equivalent resistance between 7ohm up to 10kohm.
So, the question is, worth the price to put a instrumentation amplifier ?, is the only solution to signal conditioning here ?
If I'm missing something important feel free to let me know.
Thanks in advance.
