You mean remove R1, then put a capacitor in series with pin 30 and then feed the clock into the cap?
Quote from: okw on November 10, 2024, 06:42:45 pmYou mean remove R1, then put a capacitor in series with pin 30 and then feed the clock into the cap?Is that in input pin of the crystal oscillator circuitry ?
Crystal requirements are recommended that the amplitude of the crystal is greater than 500 mV.
Would I inject the clock in XTAL_P (pin 30) or XTAL_N (pin 31)?
