Author Topic: silver etching PCB?  (Read 2430 times)
Online coppercone2Topic starter
silver etching PCB?
« on: July 13, 2019, 02:45:24 am »
So since a PCB is pretty thin, and you can make em yourself with epoxy and dielectric or ceramic board, the only question is, is there a etching method?
the obvious solution is to use silver power/ground planes and put a copper top plane and make alot of layers, but what if you wanted a silver top?
« Last Edit: July 13, 2019, 02:47:50 am by coppercone2 »
Offline KaneTW
Re: silver etching PCB?
« Reply #1 on: July 13, 2019, 06:30:10 am »
Nitric acid.
« Reply #2 on: July 13, 2019, 08:46:17 am »
concentration? temperature? additives?
Offline MagicSmoker
« Reply #3 on: July 13, 2019, 11:04:34 am »
Is your google machine broken? I Am Not A Chemist, but a basic search turns up HCl + HNO3 (isn't this "aqua regia"?), 50-70% HNO3 (stronger is not better otherwise the HNO3 will just passivate the surface with an oxide layer) and even concentrated HCl with removal of precipitated AgCl via filtration to drive the reaction to the right.
Noxious to hazardous fumes produced in all cases.
« Reply #4 on: July 13, 2019, 02:19:48 pm »
its not really defined well for things like under cutting traces and making planer structures against a backer plate as the PCB industry is.
yea and google keeps redirecting me to some kind of adult website, can you help me with that??
Offline rhodges
  • Available for embedded projects.
    • My public libraries, code samples, and projects for STM8.
« Reply #5 on: July 13, 2019, 05:15:21 pm »
I think this is a good forum for chemistry discussions:
http://www.sciencemadness.org/talk/
You may find an answer by searching. If not, I suggest using "Beginnings" sub-forum.
Currently developing embedded RISC-V. Recently STM32 and STM8. All are excellent choices. Past includes 6809, Z80, 8086, PIC, MIPS, PNX1302, and some 8748 and 6805. Check out my public code on github. https://github.com/unfrozen
Offline ChristofferB
  • Chemistry phd student!
    • My channel:
« Reply #6 on: July 13, 2019, 07:32:43 pm »
I'm not sure what you're asking - do you want to make a pcb that's purely silver on ceramic/epoxyresin substrate? or do you want a copper traced pcb that's silver plated? The first one is probably more costly or difficult to do yourself than finding an actual manufacturer.
--Chris
--Christoffer //IG:Chromatogiraffery
Check out my scientific instruments diy (GC, HPLC, NMR, etc) Channel: https://www.youtube.com/channel/UCZ8l6SdZuRuoSdze1dIpzAQ
« Reply #7 on: July 13, 2019, 08:16:44 pm »
yes, I want solid pure silver traces
same process as making a regular PCB, get substrate, press and glue on the silver sheet, mask it, do photo exposure
HNO3 will be aggressive to the resists and substrate IMO.
http://gossdesignstudio.com/sandranoblegoss/etchingster.html
Ferric nitrate may work.
« Last Edit: July 13, 2019, 08:21:40 pm by coppercone2 »
Offline branadic
  • Sounds like noise
« Reply #8 on: July 13, 2019, 09:29:37 pm »
Not sure what's the purpose of your task, but silver traces on ceramic are made by thickfilm technology (silk screen printing and backing at about 800°C). Keep im mind, that silver dissolves during soldering, that is why they use thickfilms.
-branadic-
Computers exist to solve problems that we wouldn't have without them. AI exists to answer questions, we wouldn't ask without it.
Offline DaJMasta
    • medpants.com
« Reply #9 on: July 14, 2019, 02:33:35 am »
If you're looking for a silver top, why not make a regular copper board and plate however much silver you want onto it?
Offline IconicPCB
« Reply #10 on: July 14, 2019, 04:12:36 am »
Silver plating calls for some potentially nasty chemicals ( cyanide?)
Silver on ceramic substrate is possible as mentioned above... silver ink + stencil + reflow oven
« Reply #11 on: July 14, 2019, 05:07:56 am »
so you guys think ferric nitrate etch on a bonded silver sheet to substrate with standard mask won't work?
« Reply #12 on: July 14, 2019, 05:11:15 am »
i guess you would need to test minimum solderable silver sheet thickness to see what will survive a solder cycle
Offline magic
« Reply #13 on: July 14, 2019, 07:28:24 am »
Is this for some audiophile thing? :)
Internet says it may work. But why bother if printing and baking works too?
Online vk6zgo
« Reply #14 on: July 14, 2019, 07:43:07 am »
It is possible to silverplate non conductors.
I've lost the book that had instructions on how to do it, but I think they used graphite on the non conductor.
Too long ago to remember, though!
Commercial silver plating materials are not ideal for electronics, as they have impurites added to increase surface gloss, wear resistance, etc.
The downside  of such additives is that they increase the resistivity to greater than copper.
« Reply #15 on: July 14, 2019, 03:24:37 pm »
its a minimum thermal and electrical impedance in given area thing
Online Kleinstein
« Reply #16 on: July 14, 2019, 04:20:50 pm »
There are ways to do silver deposition relatively simple from nitrate - e.g. the way old silver mirrors where made. This would allow a DIY PCB on a glass substrate. However I don't know how good the silver will adhere - this could be a problem and deal breaker.  The conductivity of silver is not that much better than with copper, so I doubt it is worth it from this perspective.  So it may be possible to use a thin chemical silver layer as a start and than add galvanic copper on top for the main conductor.
The etching would than be mainly normal copper.  I would expect the normal copper etching solutions to also attack silver, though slower. Possibly still good enough for some 0.1 µm of silver. Alternatively also selective deposition with a negative mask on the silver could be used. So etching would be only through some 0.1 µm of silver (the tricky part here could be finding a suitable protective layer (e.g. tin, gold, NiP?) to protect the copper).
« Reply #17 on: July 14, 2019, 04:55:53 pm »
you get thermal and electrical benefits
I don't see why PCB nuts can't be a thing
aluminum nitride with silver on top
I guess for best performance you would need to flame deposit silver on it or something
