I’m not sure if you’re using amplifiers to drive the motor for testing or for some kind of low noise operation, but I have an efficiency concern; I expect that the power factor on your two amplifiers could be quite bad under some conditions. This could lead to unexpectedly high dissipation in a Class B amp.
