Hello,
I'm no electronic engineering, but I'm willing to build a simple (and cheap) circuit for sending data over the power line in my house (220v ac).
As it's possible having data modulated in different frequencies travelling over the same wire pair, like in coaxial cables (obviously, I'm aware they're designed for carrying a wide range of frequencies, and just for that), I'm wondering what would take to do a very simple circuit for power line communication.
For that I have some doubts, which I will list below. I'm not lazy, so if you can't give a straight answer, but point a direction on where to head for getting these data, I will dig for them. Some of them are:
1. Is it possible for doing it (the modulation and signal injecting) with simple transistor(s)?
2. How am I suppose to "isolate" my transmitter from the high voltages running in the line?
3. What are the output peak voltage I will need for the transmitter signal output?
4. For the receiver, I'm wondering if I can use passive RC and/or LC filters for recovering the signal ?
5. Any other useful considerations.
This is all for the sake of curiosity, save the safety warnings. I wont burn my house down!
Thank you all!
