Author Topic: Buzzer Choice  (Read 1942 times)
Offline GjBobTopic starter
Buzzer Choice
« on: April 02, 2014, 06:00:47 pm »
Since this is my first post i would like to say hello to you all. On second hand i wanted to ask a question here, maybe someone has already stumbled in this kind of thing. I need to introduce a buzzer in my project to alert people in case of a falling uav in situation like technical failures. I need to to be one as loud as possible and i need have a wide range of frequency since i will need to play 2 or 3 different sound
Offline Mr Smiley
Re: Buzzer Choice
« Reply #1 on: April 02, 2014, 07:11:58 pm »
Fire Alarm Klaxon  :scared:
Is it to be located in a very large/small area,  indoors /outdoors, Small room/corridor.
There is enough on this planet to sustain mans needs. There will never be enough on this planet to sustain mans greed.
Offline aargee
Re: Buzzer Choice
« Reply #2 on: April 03, 2014, 01:12:15 am »
Mounted on the UAV (simple reversing beeper would do?) or an earth based device to notify a wide area on the ground to look up? (Air raid siren)
Not easy, not hard, just need to be incentivised.
Re: Buzzer Choice
« Reply #3 on: April 03, 2014, 12:46:24 pm »
It will be mounted directly on the uav so it can't weight to much and i rather would prefer something controlled from a pwm to produce different tones ( if i understood well from some datasheet if the buzzer doesn't have an internal circuit it will produce the loudest sound when driven by a signal at the resonant frequency but will produce also sound at other frequencies). It need to be powerd by 5v.
Offline tszaboo
Re: Buzzer Choice
« Reply #4 on: April 03, 2014, 04:59:21 pm »
Are you sure, that the electronics solution is the safest/easiest? I would guess, that a CO2 cartridge with an electronic/mechanic firing and some kind of horn would weight less, and be more alarming than any electronics horn. They go for quite some time, 20-30 secs easy for a 9g cartridge.
