I'll put in a vote for the LM7171. It fits all of your requirements, is pretty low-maintenance, low cost, and has enough GBW to share
Gobs of output current, too, you may be able to use it directly as the output without a buffer (though a simple class-AB amplifier made of a PN2222 and PN2907 and a couple diodes and resistors is cheap and will lighten its load a bit and keep it cool - this ain't no low-power op amp...).
Edit - the GBW isn't as high as I thought it was - 200 MHz (I thought 300). Barely enough if you want a gain of 10. Hopefully you don't need that much gain, though, and I did look into the AD9850 and noticed it's sine only, so at least you don't have to bother with harmonics. You could always chain two.
It shouldn't be hard to do this with transistors at that bandwidth - I don't know what the output voltage is (it's not quickly visible in the datasheet), but I'll assume a gain of about 10 is required. Up to 20 MHz
sine wave gives you a GBW of 200 MHz, which even a PN2222 can manage (though it's not nearly as easy as an audio amplifier). If you have higher-frequency content (i.e. anything but a sine wave) you'll need a better transistor, like BFS17W. The problem with this is that you are going to have DC offset on your output, which you probably don't want, and if you go to the trouble to eliminate it, you're basically implementing your own op amp. Might as well buy one.
