Author Topic: Simple current sense circuit  (Read 1758 times)
Offline kuonTopic starter
« on: March 08, 2019, 10:29:45 pm »
I built my own µCurrent device based on Dave's schematic. It works, but the output range is a bit limited and I have to monitor some current in specific range (like 5ma) which are a bit hard to monitor with the µCurrent.
I came with the following design, which is more expensive, but should have the ranges and performances I need.
As this is my first current sensing circuit, I was wondering if you could comment it.
Offline DaJMasta
    • medpants.com
Re: Simple current sense circuit
« Reply #1 on: March 08, 2019, 10:55:21 pm »
Do you need the very low current ranges?  Using lower value shunts lets you sense higher currents on similar hardware, but Dave's design is optimized for the very low currents - there are some other considerations (and in some cases some cheaper parts) that will work well on higher ranges if you don't need the very low ones.
Also worth mentioning: when you start getting shunts a few ohms or less, the contact resistance and repeatability of your switch will start to matter..  If your shunt is 1k Ohms, 50mOhms variation in your contacts is a tiny amount in the noise of your measurement, but if your shunt is 500mOhm, +-50mOhm means +-10% to your reading's accuracy just from the switch.
« Reply #2 on: March 08, 2019, 11:29:13 pm »
I don't need the 1k, 5k and 10k range, but as you pointed, the switch is important. So I picked a 10mOhm rotary switch, but it is only available in 10 positions, so I added the 1->10k range to fill it.
Offline radix
  • Country: si
« Reply #3 on: March 09, 2019, 01:14:28 am »
Just get a 2x10 switch. Use one wiper to switch the input and the other to switch the sense connector to the amplifier. The contact resistance then doesn't play a role in accuracy. Although I'm still not sure that you need all these ranges...
« Reply #4 on: March 09, 2019, 08:51:22 am »
Well, I don't need all those ranges, I just filled the 10 positions of the switch I could find in stock.
I am not sure I get how to wire the 2x switch. You mean to also switch the gain of the amplifier?
Offline JuanGg
    • My personal blog
« Reply #5 on: March 09, 2019, 10:34:23 am »
I think he means using one wiper to send the current through the appropriate resistor, and the other wiper to switch the sense line from the op-amp to that same resistor, so that you  can measure voltage across the resistor, and not across the resistor + contact resistance. Since ideally no current will flow to the op-amp, the contact resistance of the second wiper won't matter. See diagram attached.
Juan
« Last Edit: March 09, 2019, 10:43:38 am by JuanGg »
Offline HendriXML
    • KiCad-BOM-reporter
« Reply #6 on: March 09, 2019, 10:54:26 am »
Nice idea to make your own version!
Maybe R12 could be duplicated (10x) so the sensing is behind the switch?
“I ‘d like to reincarnate as a dung beetle, ‘cause there’s nothing wrong with a shitty life, real misery comes from high expectations”
Offline radix
  • Country: si
« Reply #7 on: March 09, 2019, 04:51:55 pm »
JuanGg described exactly what I meant.
« Reply #8 on: March 10, 2019, 12:50:43 am »
That is very neat, I indeed didn't think about that. I will look into a dual switch.
